Pressure effects on gases due to temperature.
I have somewhere in my memory bank a figure of 35psi/deg F temperature change, for air. Can anyone confirm this and supply a figure for Nitrogen gas?
RE: Pressure effects on gases due to temperature.
Let me guess, you're thinking of filling your car tires with N2.
- Steve
LinkedIn
P*V= n*R*T
If you're speaking of an isochoric (constant volume) compression of air, your memorized figure would correspond to pressures of the order of 13,500 psia and temperatures around 90oF.
Would you clarify?
