Air test of Repads
Air test of Repads
Is it necessary to air test all repads or is this mandatory only when the pad is split? I can't seem to find the info in Sec VIII. Thanks in advance,
RE: Air test of Repads
-TJ Orlowski
Segmented (split) re-pads must have telltale holes where EACH segment has a clear path to the hole (one hole per segment).
-TJ Orlowski
