4340 hardening processes
My company uses rings (1.6" OD x 1.4" ID x 0.5" W) made from 4340 HTSR as targets for an inductive type proximity sensor. The rings are machined from HTSR bar (HRC ~35). We are experiencing problems with electrical runout. Our theory is that non-uniform structures generated during the quench and temper of the HTSR is the source of the electrical runout. We have tried making the rings from 4340 Annealed bar (HRC ~25) and observed an improvement in the electrical runout.
The problem with using annealed material is that one of the axial surfaces of the ring is also used as a landing bushing and we need to have a hard surface that will wear well. We are concerned that annealed material in an untreated state will be too soft. Strength is not an issue, it is only an issue of hardness.
We have tried to normalize the annealed 4340 (1700F for 1 hour and air cool). This seems to only slightly improve the hardness. Do we need to machine away a small layer to properly measure the hardness after normalizing?
What are some other methods (besides normalizing) to treat an annealed material to achieve a surface hardness of ~35HRC while maintaining a uniform structure in the bulk of the material?
RE: 4340 hardening processes
You may experience large deviations of magnetic properties for every new batch of material.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
