stamp Vessel without UG-46 (f)
We are fabricating a stamp Vessel (ASME Sec VIII Div 1) with dia 1000 mm,  which do not have any Manway only one handhole of 14'' (as per client datasheet).
Since above conditions are not fullfilling UG-46 (f) (3) our inspector is not ready to register under asme,and our client
recommended to use project spec or data sheet first and if not clear then use codes.
Any suggetions are welcomed.
RE: stamp Vessel without UG-46 (f)
You need to talk to your client. They may be able to make one pipe connected to one nozzle removable so you can use UG-46(f)(7) to meet the code requirement.
It is strange for your client to specify a 14" hand hole in lieu of 16" manhole to meet code requirement. I typically see a 8" or 10" handhole.
Jasmel,
I think you can bypass mandatory manhole of UG-46(f)(3)when manhole were not impracticeable. Since, in the current case, mandatory manhole was not impracticeable because 14 inch could have been 16 inch easily.
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
Jasmel,
Sorry there was a little mistake in my above post.
I think you can not bypass mandatory manhole of UG-46(f)(3)when manhole were not impracticeable. Since, in the current case, mandatory manhole was not impracticeable because 14 inch could have been 16 inch easily.
Nasir
Welding Engineer
PAKISTAN
In this case, if there is a nozzle 16" or bigger, then you can use it to satisfy the code requirement.
Jasmal,
I am of the view, since 16 inch manhole was not impracticeable so UG-46(f)(3) could have been complied with easily. You can go to UG-46(f)(7) only when 16 inch manhole was really impracticeable.
Please add further.
Nasir
Welding Engineer
PAKISTAN
There is nothing wrong to designate a large nozzle as manway as long as it can be removed easily for access. There is no code requirement that a manway has to be totally closed by a blind. Thinking about top manways on reactors. It also serves as inlet nozzle.
well, if client says, give it a try and if it does not fly comply with the Code: easy change it to a 12x16 manhole and you're good.
