Family Table problem
Dear All,
when i create a new revision of an assembly(A)that contains some stand-alone parts and a member(B) of an other family table(B). The assembly itself also contains a family table and i use the member(B) in the family table(A) to create different states of the assembly(A).
I get follow information/warning windows (see screen shot).
For every member of assembly(A) i create i get the warning that the family member(B) is modified and i cannot save it, obviously because this is only possible from within the table(B).
The other parts are released so i cannot save them either, but those warnings shows up in the text info window (one click=close solution)
In the end i end up with as much info windows as i created members(A) in this case 12 pieces. But we also have tables with +-100 or more members, i could get i my finger hurt in the end with close clicking/space tabbing those windows. thumbsup2
Is there a solution for this behavior?
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
RE: Family Table problem
MickyV007,
Have you looked into using
File, Utilities, Customer Defaults, Assemblies, General, Miscellaneous, "Display Message when Modifying Read-only Parts" ?
Regards, Joe
Sometimes it can be so simple!
Thanks a lot Joe.
Best regards,
Michaël.
