HIC Tested plate procurement
I am preparing a material take-off / technical deliver condition for HIC tested plates Also this plate is to be procured for Div.2 job.
1. What all special criteria shall I need to follow while purchasing the HIC tested plates along with the material specification requirements. ( the plate is of material SA 516 Gr. 70 N and SA 387 Gr.11 Cl.2).
2. Which all NACE codes and requirements comes into picture while procuring HIC tested plates.
3. Also can any one tell the lead procurement time of these plates, means what will be the delivery schedule for these HIC tested plates.
RE: HIC Tested plate procurement
If you are getting existing plate that hasn't been HIC qualified yet, you do run the risk that the ensuing test fails.
Google Prudential's PS-10 and PS-50 specifications. They are quite good.
SNORGY.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
