Substation Design
Substation Design
Substation Design
Can any one point to books or publications that deal with substation design. In the past I had to use the REA manual. But this manual I do not believe ever received an update after the 80's.
RE: Substation Design
Suggestion:
Current industry standards for substations and the manufacturers' substation literature might be a good and sure start.
Suggest you also get a copy of IEEE Std 80, IEEE Guide for Safety in AC Substation Grounding. Make you get the latest edition, just published.
I have the standard spread all over, having design information and methods in one place expedites the resolution of issues or even designing items. I was able to browse at one time an ABB Substation book ( For their eyes only ). I can only tell you that it really helps.
Suggestion:
Try
Smeaton R. W. "Switchgear and Control Handbook" by McGraw-Hill Book Co.
You may want to look at "Standard Electrical Engineering Handbook" by McGrawHill. It has one chapter covering Substation Design
The REA guide is probably the best one-stop guide to substation design available outside of taking a substation design course.  Other good references would be IEEE Power & Engergy - Substation Standard, as well as the Power & Engergy - Switchgear Standard. The old Westinghouse T&D blue book is a good source, I think ABB sells it on CD-ROM. If you have a more specific question I may be able to help you.
Has the REA books received an update if so are they available.
The web site for RUS has many of their documents available in a pdf format
The version carried by the RUS Site is from 1978, while the CO OP Association has the Substation Design Book Revised in 1993. The CO OP association will only sale to CO OP's.
I SUGGEST TO TRY WITH "SWITCHGEAR MANUAL"BY ABB CO.
Is the manual for sale in a specific place, I tought it was something only available to ABB and very specific customers.
