High temperature colenoid coil
I need to run a solenoid at 500 deg C around 300 V for R&D work.
6-10 amps
No cooling available.
Continuous duty
Apart from resistance effects of temperature most insulations will be breaking down at temperatures above 150 deg. C
Coil must be fairly compact and wound like traditional solenoid so thick insulation like ceramic beads not feasible.
Can anybody recommend anything?
Many thanks.
6-10 amps
Continuous duty
Many thanks.
RE: High temperature colenoid coil
Cut the conductor from the solid, like a Heli-Cal coupling.
Mike Halloran
Pembroke Pines, FL, USA
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
Mike
