TNC530 ISV simulate M140
Hi All,
  I have a post with vnc for a Heidenhain TNC 530 which doesn't simulate the M140 MB command (move back along tool axis). Does anyone know how to add this into the vnc controller. I have done a bit on the post side but nothing with the vnc.
Thanks in Advance
Cheers
  Steve Griffiths smile
If you want to make apple pie from scratch, first you must create the universe!
RE: TNC530 ISV simulate M140
Try using user defined events. To take out the M140.
I am not so trained on ISV.
Any ideas on how to manage the M140 MB MAX?
Thanks in advance
Cheers
what you could do write some code in the preprocess procedure (vnc file) that will first recognise the phrase and then you will have to tell nx what to do.
Steve,
I wanted to ask you before, but here it goes.
An UDE is not necessary at all here, I assume you already have M140 in your postprocessed output
The easiest solution, but not the right way, is to define some intervals e.g. from A to B move to position 1, from C to D move to 2 an so...
The proper solution involves some basic maths (not rotation-translation matrices as in cycle 19), just move the tool from where you are in its real axis direction in simulation, until you get intersection with one of the 3 plane's equation: one that defines Z limit, other Y and finally X, each intersection defines a vector, the shortest one will be the target point
that should give you some ideas
Any question feel free to contact me
