Suggestions for Pro/E user moving to SW?
9
hi all,
I'm learning how to use SW, and was wondering if any of you had any suggestions on how to become a better modeler. (or any references to learning how to be faster)
anyone?
RE: Suggestions for Pro/E user moving to SW?
Practice, practice, practice!
Start with the built-in tutorials.
Read the Help files.
YouTube has loads of examples.
The SW bloggers often have some great tips.
SolidProfessor and igetit offer relatively inexpensive online tutorials.
Just push buttons to see what happens.
3
How to become a better modeler?  That's not anything specific to Pro/E or SW.  That's just good planning and good sense.
As far as learning SW goes, basically, you will need to learn to lighten up pn the need to fully constrain everything.  SW doesn't require it, and that can actually help the design process.
I guess I want a better workflow. Modeling is not a problem, I've learned after 14 years of Pro/E.
I think the constraining things is my problem.. I'm constraining everything til it becomes black in my sketches. I've heard about that; so you're saying it's not important?! won't it cause crashes later on down the line?
Also, when I put an assembly together, I want all the planes visible, all mates assigned, and find it bothersome whenever I need to alter their mates (#view mates, #edit feature, delete mate, #mate, enter enter)
also, I miss the center click feature of Pro/E. it makes things a million times faster than in SW.
Do you keep your hand on the keyboard? Which keys do you all assign for your mapkeys/macros? Maybe someone can share their macro file?
Thanks!
The things that make or break a CAD jockey aren't specific to any specific product.  If you were successful in Pro/E, you can carry that over into SW.  (I did.)
Keep your eyes open to differences.  Not every difference is a disadvantage.  The true craftsman uses all of the tools characteristics (even the unintended ones) to his advantage.
I agree completely, I've invested quite a bit into SW (not just money, but time), and I'm trying to find ways to become faster.
There's lots of good things about SW, I just need more tips on how to become more efficient with my movements.
Are you using the S key shortcut? Extensive customising for each mode (sketch, part, assy and drawing) can eliminate the need for the Command Manager (the ribbon) and many toolbars. That can save a lot of mouse movement ... and screen real estate.
What does the center click feature of Pro/E do? Is it similar to the right mouse button in SW?
Hi, engrnick:
What is "the center click feature of Pro/E"? There is no such a thing that is a million times faster than in SW.
Cheers!
I think a teeny-tiny bit of hyperbole was being applied with that statement.  smile
The center click in Pro/E is a huge time-saver.. I'm looking for something similar in SW. the closest I've found is the escape key, but then you have to re-click the feature you want.
-in sketcher mode, once you've finished a tool, it cancels and brings you back to the pointer
-in line drawing tool, it ends the line you're working on
-in feature edit, it selects the highlighted default selection
-it pushes the "OK/finish" button on a lot of features and drops you back to the main window
etc.
I like it because I don't have to let go of the mouse or need any hand commands. I hope someday to be as efficient in SW as i am in Pro. :/
CorBlimeyLimey, I will try the s-key.
hey, the S-key is handy, like a secondary context menu.
Also does anyone know of any way to select faces underneath the current face? Similar to cycling the right-click feature in Pro..
I've been trying to select faces directly under the top surface, and the only way I've found is "Select Other", but i'm looking for a faster way to get the interior surface of a box.
Icons can be added to the S key via RMB > Customize. Just drag and drop new icons to and from the S key box.
Select Other is the only way to drill through faces below the cursor. When mating or selecting hidden faces the Isolate function is invaluable.
I miss "trajpar" and variable section sweeps.
Select faces under others use "Select Other"  As to major productivity increase - grab a "Space Explorer".
You would not get an "A" in my class.
There are times, but very rare I would not require fully constraining.
I've been overqualified for that class for well more than a decade.  You go do your "thing". I'm busy designing.
A star to TheTick for that response.  In general I agree with rollupswx and wouldn't recommend to anyone to leave things unconstrained... but can concede that some swoopy stuff might need to be left floating.
-Dustin
Professional Engineer
Pretty good with SolidWorks
During World War One, the RAF lost dozens of pilots training in Sopwith Camels due to the high torque characteristics of the engine.  Many a ham-fisted pilot had gone into a death-spiral due to mishandling this characteristic.
However, many veteran pilots found this to be a very useful characteristic.  With a little practice, these pilots could take advantage of the torque characteristics to get their planes to snap into surprisingly tight turns, enabling the Camel pilots to shake off enemies and subsequently get on Jerry's tail.
The things that can kill a newbie can be the same things that help ensure a long and prosperous career for the aces.
engrnick, along with the s key, check out mouse gestures. I also use keyboard shortcuts, macros, and have used a gaming mouse at times with extra programmable buttons and a 3d connection space navigator in the left hand.
diego
Something I wrote to another Pro/E expatriate some time ago.  Someone else once thought it useful enough to requote.
Quote (Tick):
The biggest challenge is letting go of all the stupid things that Pro/E makes you do. SW is much simpler.
Things you will miss:
•variable section sweep
•"trajpar"
•coordinate systems that are actually useful
•control of planes
•control of sketch horizontal reference
Things you won't miss:
•million-mouseclick features
•inability to salvage a sketch after a feature is deleted (circa 2001)
•Pro/E's cryptic layer scheme
•zoom-specific sketch constraints
Add to the "Miss" list: Pro/E's tools for editing and reimporting imported geometry and reconnecting downstream references.
To stop creating lines, double left click.  This works for what ever sketch tool you are using.  You can then start a new line the next time you left click.
If you have a higher end mouse with some extra buttons you can program them to act similar to the other functions you use to be able to do with the center mouse button.  It will take some time to remember the new mouse commands though.
My suggestion: Sit back, relax, and enjoy the smart decision you have made! It will make your life so much easier!
Also, get ready to click less, design more, and get distracted less by rediculous fail loops, and non-intuitive feature generation. Be prepared for more design freedom!
Thanks! the double click is a good one. I don't  use a mouse due to Pro/e's old method (pre-Wildfire) need of a million clicks. Now it's not as bad, but my hand is damaged, so I have to use a tablet.
Take care of your hands, fellas!
There are things I like about SW, things I like about Pro. Whatever, some things are easier to do in Pro than SW, and vice versa.
We could get into the same argument about Android vs. Iphone, or Mac vs. Windows.
Thanks for your help guys. I'm surprised so many people liked TheTick's comments. He must have a fan club haha
Cheers!
TheTick is a handy forum member here, but I'm on the side of rollupswx in terms of constraining things. Undefined assemblies and sketches just cause major headaches down the line, especially if work gets handed on to different people.
F16's don't have torque steer
Remember that you can continue to use the RMB to remove surfaces when using select other.
I tend to have one hand on the keyboard, and use a lot of custom shorcut keys, some of which fire up custom macros, remember you can record common sequences of commands.
Don't set up too many shortcuts at once though, you'll just forget them.
I have a SpaceNavigator for all my zooming/panning/rotating, etc...
And I have a mouse with 2 programmable buttons... one set to CNTL, one to ALT.
Also, I recently reprogrammed the middle mouse wheel/button as the ESC keystroke... LOVING IT..! I wish I could reprogram the wheel/zoom as something useful too.
Speed in modeling is a deceptive goal, once you become proficient and efficient... speed happens.
Jack L Tate - Xtreme Tower Products - SolidWorks 2011 SP2.0 - Windows XP Professional - RocketFish Mouse - SpaceNavigator - Pandora Radio - Swingline Stapler - Pop Tarts - C8H10N4O2
Relax you are no longer forced into an Object Action mode where you have to select 2 Quilts (joined surfaces) to get the Merge icon to become available.
SolidWorks can use a single sketch with multiple profiles where you don't need to use the entire sketch for a feature you can select which portions to use. Probably my biggest gripe with ProE.
SolidWorks is one word not 2 as I originally thought take a look at my early posts.
Hey check this out buddy you can float toolbars in SolidWorks.
From "ProE Help"
You can drag a toolbar by its handle and place it in a docked position on the top, left or right side of the main window. You cannot float a toolbar as a separate window. MASSIVE UI FAIL
Unigraphics now NX did this on UNIX so what's PTC's problem.
Be happy that any line can be used for a mirror or symetry constraint not just infinite centerlines. Construction geometry can be used as centerline.
You can create ellipses at any orientation which is only available in Wildfire 5 and later ProE versions where ProE added a lot of things missing from ProE including constraints based on selected items.
VSS Variable Section Sweeps can be done using guide curves and the Pierce relation in sketch.
Forget about using Copy Paste as it works for little to no feature types in SolidWorks except Sketches and Extrudes.
You can stop having to hold down your CTRL key when a selection dialog is available.
QuerySel >> Use Select Other option in Right Click or Application (apps key) pop-up menu. This does require a few extra clicks since tapping the Right button doesn't cycle to next available selection. It also gives you a Selection Menu like Sel from list in ProE.
After Sel Other is invoked you can right click on surfaces to remove them from display Shift + Right Click to re show.
Rectangle Selection will actually work outside of drafting mode.
Direction     Objects included
Left to Right Selects items inside rectangle
Right to Left Selects items inside of and crossing rectangle.
Invert Selection is usefull. To select all surfaces you can
1. Pick a single surface
2. Use invert Selection I suggest CTRL+I as shortcut key I use Alt+I for Isolate
3. Pick the original surface again with single press of CTRL.
Middle button is great in ProE but it's basically like the Return key in picking the default option. Esc isn't really needed just select your next icon like Arc or Dimension.
Return will repeat last command activated.
You can stop using underscores in file names because you are allowed to use spaces even in the Model Tree or SolidWorks ripped off Feature Manager.
Wait a few years and maybe you'll be able to detach the Feature Manager like ProE has allowed almost since it's its inception.
ProE does allow you to customize the columns of the Feature Tree a lot better than SolidWorks.
There are way too many things for me to suggest so I think I'll stop here but may add additional things later on.
Relations in sketch can be configured unlike (Constraints) in ProE
Where SolidWorks still fails:
Configs or System Settings ProE does not require special registry permissions and uses simple to edit text files.
ProE can load a diffeerent Config.pro Options or Config.win Window settings in session SolidWorks requires exiting program loading settings then restarting SolidWorks.
Multi key shortcuts like
11 = Line
12 = Line 2 tangents
13 = Centerline Construction
14 = Centerline Geometry
Autocad can do this and does it well
SolidWorks restricts a lot of buttons from being used as shortcuts. However simple keys like CTRL and Alt cannot be used easily for mapkeys cause it's based on key presses mainly alphabetical as words not symbols or specialty keys.
Michael
Re: sweeps
What is missing in SW that is in Pro/E VSS:
•Tangency when using edges for guide curves (very handy!)
•"trajpar" variable to control a parameter w.r.t. relative position on a sweep path
Really useful stuff Michael!!
This is exactly what I was looking for.. Thanks a lot for this, I'd give you more stars if I could..
Engrnick The two Exclaimation points above help in showing your appreciation. I'm glad you liked my post.
"The Tick" You are absolutely right.
Why do you think my ProE twitter name is @trajpar? :)
Yes Variable Section Sweeps are powerful and trajpar can be used to evaluate areas or dimensions in terms of Sketched Graphs or Relations. I agree with you fully in regard to the VSS fearure.
However the SolidWorks sweep does a reasonably good job if these aren't necessary. V.S.S.does give much better orientation along sweep control instead of the follow path, path and first guide path and 1st and second guides etc.
SIEMENS is making an NX version for MAC and hopefully SW can do the same without requiring clouds. When I was an AE I hated the way MAC users were treated because their Hardware was unsupported and had a lot of Macbook users that I still went out of my way to help.
Another thing that annoys me about SW is their new UI forces black text in status bar and Measure dialog so if you use a dark background you can't read the text. The SolidWorks name is displayed in white or light blue which are the colors I use for text with black window background. Many webpages suffer the same problems. ProE has a System colors dialog where you can set your own colors instead of the Graphical Command Manager Gradient from Bright to Brighter.
Michael
TateJ,
You stated that you are using a SpaceNavigator spaceball in Solidworks. I am using 3DConnexion Spaceball which is pretty much the same thing that is used to rotate/zoom/pan. My question is: is there a way to pin the rotation points in Solidworks 2010? For example, if you have a long part and you rotate that piece it may fly off the screen or out into space. If one could pin the rotation point to say an area that is being worked on like the end corner or something of that nature so it rotates about that point, it would make life alot easier. Hate to revert back to using the mouse seeing that it helps reduce mouse clicks and moves some of the work to the other hand. Any tips here?
Will
Will,  quickies: (there are others, esp since you have a spaceball thingy)
-Hold down the ATL key while pressing MMB for locking the axis temporarily.
-Click the MMB once on a feature or other element, then click and hold the MMB and move the mouse round to rotate your part about the feature you selected.
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
Will...
The latest drivers have altered my methods a bit.
But yes you can do what you want. but you definately don't want the latest drivers. You want the drivers specifically written for your device. I used a SpaceBall untill 2/1/10... then got a navigator. I had to find the older drivers that worked best for my SpaceBall & they were not the latest.
Jack L Tate - Xtreme Tower Products - SolidWorks 2011 - Windows XP Pro - RocketFish Mouse - SpaceNavigator - Slacker Radio - Swingline Stapler - Pop Tarts - C8H10N4O2 - Rental Bowling Shoes - Titanuim Spork - And that's all I need!
This is making me miss Solidworks...
Been using Pro-E for the last 8-9 years... sigh...
Nobody even mentioned the better drawing environment in solidworks... Ballooning, dimensioning, etc... All much better.
David
