chem injection quill in ductile iron piping
Injecting Caustic, Bleach, Flouride, and Phosphate at a potable water well treatment system.  The proposed piping is 6" ductile iron.  What is the best way to connect the injection quills?  I was thinking a simple service saddle might be the most operator friendly but thought a corp stop with a shutoff might come in handy as well. What do you think?  I suppose the easiest solution would be a direct tap.
RE: chem injection quill in ductile iron piping
A corp stop with a shutoff is the typical method.
Direct tap the corp stop or use a saddle?
I believe the most common is a saddle.
