study statis failed but finishes run
So this has happened to me several times now and I haven't been able to find information about it. While running the status of the study will change from running to failed, but the model will continue to run and does not report an error in any of the logs. after the run is complete the status changes to complete and everything looks fine, but I don't feel comfortable trusting the results on runs were this happens.
RE: study statis failed but finishes run
I have had similar experience when viewing the summary tab and switching to the checkpoint tab.  It seemed to be a bug of wildfire 5.0 rather than a failure especially since there weren't any reported errors.  So far I have not noticed this in Creo 1.0.
Hope that helps,
- J -
Thanks for the reply. I hadn't notice that the error occured when switching from the summary tab to the checkpoint tab, but that is when I see the error as well.
Thanks for the help
