EKILL Command Object
I've been teaching myself APDL and decided to make a ekill macro for use in Workbench. I wanted to automate the process as much as possible w/ the minimum amount of setup.
I did not want to use separate load steps.
I was mainly inspired to use components from this:
http://ansys.net/?mycat=tnt_einar1
It appears to be working under specific circumstances and I would like the community to take a look at it and possibly tweak it, etc.
It's designed to be used for any static analysis with a single part or an assembly using the same materials. Have NOT tested this on an multibody analysis (yet).
So far I have used a ASTM-D638 test as a benchmark.
Any feedback is appreciated.
At the moment the macro does the follow (or was intended to):
1. Breaks up the solution into sub-steps w/ sub-steps using a Do loop.
2. At each break, it stores elements meeting "failure" criteria into components.
3. Writes the a component file.
4. Issues a restart and reads in the component file and systematically kills the elements.
The *get and *status statements were used for troubleshooting.
! Doug Mangels
! 2011-07-01
total_steps=100
subst_int=1
subst_max=10
subst_min=1
*do,i,1,total_steps
  /gopr
  time_step=i/total_steps
  time,time_step
  nsubst,subst_int,subst_max,subst_min
  outres,all,all
  esel,all
  solve
  finish
  /post1
    set,last
!    esel,s,live
!    *get,live_count%i%,elem,0,count
!    esel,inve,live
!    *get,dead_count%i%,elem,0,count
    esel,all
    etable,stress,s,eqv
    esel,s,etab,stress,ARG1
!    *get,stress_ecount%i%,elem,0,count
    cm,kill_stress%i%,elem
    cmsel,s,kill_stress%i%,elem
    esel,all
    etable,strain,epto,eqv
    esel,s,etab,strain,ARG2
!    *get,strain_ecount%i%,elem,0,count
    cm,kill_strain%i%,elem
    cmsel,s,kill_strain%i%,elem
    allsel
    cmwrite,kill_list,cm
    parsav,all
  finish
  /solu
    antype,,restart
    parres
!    *status
      /input,kill_list,cm
    *do,k,1,i
      ekill,kill_stress%k%
      ekill,kill_strain%k%
!      *status
    *enddo
*enddo
finish
