RS485 Comm Cable for Outside Use
Can anyone please tell me what communication cable anyone one reccomends or uses for RS 485 communication outside in conduit? I use to use Belden 9742 but that is not reccomended for outside use the jacket is made out of PVC. Any help would be appreciated.
RE: RS485 Comm Cable for Outside Use
Dan - Owner
http://www.Hi-TecDesigns.com
The Belden 9742 cable you mention isn't really meant for communications. I know it works, but it technically should not be used for that purpose. The problem is that the cable size and construction isn't meant to support RS-232 or RS-485 communications.
For proper operation, RS-485 communications should be carried across a small gauge (22 – 24) that has an appropriate twist and 120 ohms impedance. The OSP Cat-5 works great for that purpose.
If you go to Belden's web site and search RS-485 in their e-catalog, you will see some examples of industrial comms cable.
Manufacturing of RS-485 Cables
Belden manufactures RS-485 cables. See part numbers 8132-8155 and 9841-9844.
Plenum RS-485 Cables
Belden manufactures RS-485 cables. See part number 1269, 8995-8996, 82729, 82841-82842, 88102-88107, 88109, 88112, 88118, 88125, 89182, 89207, 89705, 89728-89732, 89734, 89757-89758, and 89841-89842.
Run Length of RS-485 Cables
The maximum permissible length is a function of several variables including data rate and noise. The appendix of the RS-485 standard contains application guidelines including information related to cable length.
http
