A53B Post Heat Weld Treatment
If I use piping ASTM A53-B is thru I have to do PWHT on it, is better and cheaper used SA-106-B??
RE: A53B Post Heat Weld Treatment
PWHT is only required if the governing construction code requires it to be.
And in what specific situation would A53-B (Type E?  Type S?) need PWHT but A106-B not need it?
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered.  It is offered with the understanding that the author is not engaged in rendering engineering or other professional service.  If you need help, get help, and PAY FOR IT.
