Corrosion resistance material for Spring
Hello guys,
I have to modify material specification for spring hangers of a plant which is located in severe offshore condition and is dealing with heavy corrosion. On the other hand I'm a stress analyst and don't have too much info of spring material, so can you please advice me of an appropriate material for the spring coil according to the mentioned condition?
Thank you
RE: Corrosion resistance material for Spring
EdwinP,
The most common corrosion resistant spring wire is 302 or 304.  Sometimes 17-7 PH is also used.  It would all depend upon your spring stress, loading, life cycle, etc.
Hope that helps.
Terry
http://www.eng-tips.com/viewthread.cfm?qid=298618
 Please review the discussions,perhaps it might interest you.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
