Can effective piezoelectric transformer be implemented for this?
Is it possible to use a piezoelectric transformer to step up voltages of 3 to 12 volts to as much as 5 kilovolts? Below are more details of what I would like to do:
Input into transformer: square waves, 0 to 12-volt amplitude with frequency range of 100 Hz to 100 KHz
Output from transformer: square waves with 0 to 5 kilovolt amplitude, 100 Hz to 100 KHz
Also, what companies in the US supply piezoelectric transformers or components for making them? Any tips or advice for using or implementing the transformer in order to avoid pitfalls? Thanks!
RE: Can effective piezoelectric transformer be implemented for this?
...to find Application Note AN81-1 written by Jim Williams (sadly, he just died a couple of weeks ago) on this subject. The note mentions CTS Wireless Components for the coauthors.
5 kv is about an order of magnitude higher than the usual back light application. Might not be easy.
