Minimum distance between assembly components
Is there a quick way in NX7.5 to get the minimum distance between two components (with multiple bodies in each component) in an assembly?
Thanks.
RE: Minimum distance between assembly components
Analysis>Measure Distance
In dialoge box set "Type" set to distance and "Measurement" to minimum
Set your selection filter to "Component"
Pick your components in the assembly navigator.
I am not quite sure what your asking.   Can you be more specific
Norfolk Southern Railway
Charlotte Roadway Shop
If you are looking for clearances between components use Assemblies - Components - check clearances.
If you have the advanced assy license you can use the Analysis - Assembly Clearance option.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
The Analysis -> Measure Distance... should work just fine as long as you set the selection filter to Component, even if there are multiple bodies in one or more of the Components.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
