Wide Flange Column weld to Base Plate guide
can someone refer me to a guide how to check the weld of WF steel column to base plate. i am checking a calculation seem straight forward but he has corner stress ft, etc..
RE: Wide Flange Column weld to Base Plate guide
the allowabe ASD for Fw is 0.3 (70) x 0.707
if i were to compare this with actual lrfd loads/stress.
what should be the Fw formula including lrfd phi factor
phi x 0.6 x 70 x .707
thanks,
