NX Open - Ref sets
NX Open - Ref sets
NX Open - Ref sets
I'm trying to get the list of ref sets for each part open in my session.
So far I've only been able to find how to create a new ref set.
Anyone managed to do this?
Mark Benson
Aerodynamic Model Designer
To a Designer, the glass was right on CAD.
RE: NX Open - Ref sets
Since a Reference Set ONLY plays a role when working in the context of an Assembly, the better question would be; "How can I find out which Reference Set is being used for each Component part in my current Assembly?"  And you do that by opening the Assembly Navigator and making sure that you have toggled on the 'Reference Set' column.  And if you have sub-assemblies and you wish to see them as well, make sure the you've toggled on the 'Expand All' option.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
I just noticed that the title of your entry mentions 'NX Open'.  Obviously my responce was based on what you would do during an interactive session of NX.  Sorry for the confusion.
That being said, this should provide you a hint in that the command that you're looking for would be one which deals with the Components of an Assembly and not with the open Part file itself.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John,
Thanks for your reply.
What I'm trying to do is programatically find the ref sets that exist in a part so I can list them as options to the user in a form so they can select the correct ref set to add that part into an assembly.
I think I've now found the function which is part of the basepart class and hopefully works from workpart.  It's called "GetAllReferenceSets".
Mark Benson
Sounds like what you're looking for.  Good luck.
John R. Baker, P.E.
Industry Sector
Cypress, CA
MSPBenson,
I hope this will help.
    '-----------------------Searching the bodies in the ref set ----------------
    Public Function test() As Tag
        Dim theSession As Session = Session.GetSession()
        Dim theUFSession As UFSession = UFSession.GetUFSession()
        Dim theUI As UI = UI.GetUI()
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        'lw.Open()
        Dim iBodies(0) As IBody
        Dim num_ref_sets As Integer = 0
        Dim ref_sets() As Tag = Nothing
        Dim ref_set_name As String = ""
        Dim origin(2) As Double
        Dim matrix(8) As Double
        Dim num_members As Integer
        Dim members() As Tag = Nothing
        Dim ref_set_name_to_edit As String
        Dim seedString As String = "MODEL"
        Dim bodies_found As Integer = 0
        Dim test_ertek_1 As NXObject = Nothing
        Dim test_ertek_2 As NXObject = Nothing
        Dim t_body As NXObject = Nothing
        'Dim t() As String
        'ReDim t(0)
        Dim i As Integer = 0
        Dim j As Integer = 0
        Dim ref_set As Tag = Nothing
        Dim ret_count As Integer = 0
        Dim mems_1 As Tag() = Nothing
        Dim mems_2 As Tag() = Nothing
        Dim v_ref_set As String
        Dim NULLTAG As Tag = NXOpen.Tag.Null
        Dim objectTag As Tag = NXOpen.Tag.Null
        Dim vissza As Tag = Nothing
        Try
            theUFSession.Obj.CycleObjsInPart(workPart.Tag, NXOpen.UF.UFConstants.UF_reference_set_type, objectTag)
            Do
                Dim myrefset As ReferenceSet = Nothing
                Dim myObject As NXObject = Nothing
                myObject = NXObjectManager.Get(objectTag)
                myrefset = CType(myObject, ReferenceSet)
                'MsgBox("Name = " & myrefset.Name)
                If myrefset.Name = "MODEL" Then
                    ref_set = myrefset.Tag
                    i = i + 1
                    theUFSession.Assem.AskRefSetMembers(ref_set, ret_count, mems_1)
                    'lw.WriteLine("---------" & mems_1(0))
                End If
                If myrefset.Name = "TRUE" Then
                    v_ref_set = myrefset.Name
                    j = j + 1
                    theUFSession.Assem.AskRefSetMembers(ref_set, ret_count, mems_2)
                    'lw.WriteLine("---------" & mems_2(0))
                End If
            Loop While objectTag <> NULLTAG
            If j = 1 Then
                vissza = mems_2(0)
                'MsgBox("Name = " & v_ref_set)
            Else
                vissza = mems_1(0)
            End If
            'test_ertek_1 = mems_1(0)
            'lw.WriteLine("this comes back: " & vissza)
            If i = 0 And j = 0 Then
                Return vissza
                Exit Function
            End If
        Catch ex As Exception
            'MsgBox("Nincs Hasab attributum definialva!" & ex.GetBaseException.ToString() & vbCrLf)
            'MsgBox("Nincs MODEL vagy TRUE refset!")
            'workPart.SetAttribute(db_part_title, db_part_ertek)
        End Try
        Return vissza
    End Function
This will do exactly what you're looking for and works on the NX Work Part:
Do
   ufs.Obj.CycleObjsInPart(s.Parts.Work.Tag, UFConstants.UF_reference_set_type, refset)
   If refset <> NXOpen.Tag.Null Then
      ufs.Obj.AskName(refset, name)
      ' cbbRefSet.Items.Add(name) ' this add the ref. set name to a combobox named "cbbRefSet"
   End If
Loop While refset <> NXOpen.Tag.Null
Thanks to everyone who posted.
I'm writting this to sun in NX7.5 which has improved functioanality when compared to NX6.
I've looked befor in the NX6 help docs but never found it.  A quick look in the NX7.5 ones and ther it was.
My brief has changed slighlty now.  I want to click on a part in a list in my form and display it's relevant ref sets in a combo box.  I check if there is currently displayed value of ref set in the list and this is the input of "original"
Here's what I ended up with:
Private sub combobox_fill(byval original as string)
ComboBox1.Items.clear
Dim myrow As DataGridViewRow
        myrow = DataGridView1.CurrentRow
        'MsgBox(myrow.cells(0).value)
Dim ref_check_part As Part = CType(theSession.Parts.FindObject("@DB/" & myrow.cells(0).value), Part)
'here's the important line for grabbing the ref sets of the part clicked on
dim  ref_set_list as referenceset() = ref_check_part.GetAllReferenceSets
dim ref_index as integer
for ref_index = 0 to ref_set_list.length-1
ComboBox1.Items.Add(ref_set_list(ref_index).name)
next
if ComboBox1.Items.Contains(original) = true then
ComboBox1.SelectedItem = combobox1.items.indexof(original)
ComboBox1.Text  = original
else
ComboBox1.SelectedItem = 0
ComboBox1.Text  = combobox1.items(0)
combobox1.refresh()
end if
end sub
This could easily be used in a loop to achieve the original question I posted above.
Mark Benson
