Required Thread Engagement for Bolt Tensile Strength
Is anyone aware of texts that will allow me to determine the necessary thread engagement to achieve the AISC tensile strength of a bolt/threaded rod?
I have a 3/8 HRS plate being bolted to a tapped 3/4" HRS plate with 3/8" bolts.  The client will most likely want stainless bolts, as I am sure that could affect the responses.  I know I can easily achieve a nuts depth or (1) bolt diameter engagement, but this connection made me wonder if there was something out there that gave a threaded connection strength based on number of threads engaged.
TIA,
Juston
Juston Fluckey, E.I.
Engineering Consultant
RE: Required Thread Engagement for Bolt Tensile Strength
Discussed numerous times. Tried a search?
Mike
I have, but after the third page of search results, I decided to start a new thread.  Perhaps you could post a link to one of these numerous discussions?
Thank you both.  The link provide by desertfox is probably more applicable to my application since my threaded plate is probably weaker than my bolt material.  I will find out for sure when the client lets me know what type of bolt they want to use.
Use the calculation for thread engagement from ASME D1.1.
A question properly stated is a problem half solved.
Always remember, free advice is worth exactly what you pay for it!
http://www.ap-dynamics.ab.ca/
