Ling Electronics Shaker LS-100 docu
I've got Ling Electronics Shaker LS-100. Unfortunately I've no any documentation about. In particular I'm interestin for interface to connect shaker to the amp. Please help!
RE: Ling Electronics Shaker LS-100 docu
I'm sure Ling would be able to help you
http://www.lds-group.com/
M
Dr Michael F Platten
German subsidarry of LDS Group don't have a clue about LS-100 shaker from Ling Electronics. sad
I'm new here in the forum but no beginner in research smile I've already written to the company. The problem is, no answer till now sad I you have information about shaker it will be very helpful! Thank you
I ufortunately there is no additional equipmet at all (no cable, no amp. I have power 4-quadrants-amp 26000W smile I can use for shaker control. I also have dif. acceleration sensor to measure actual acceleration value for closed loop control. To do this I need pin assignment and maximum ratings for current.
OK, how many termiinals does it have? Does it have an internal cooling fan?
I see from that pdf it is a smallish one, externally cooled. Therefore the only connections are across the speaker coil, and possibly an earth, and possibly a no-airflow sensor. A techie with a ohm meter will be able to sort you out on all that.
I'm amazed you are getting no response from Ling.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
Ling Electronics is not existing any more. The company was bought from Data Physics. They produce similar shaker LE-LS70. I attached info I got. The shaker buid up of two coil that connected inside. The connector have vour upper pins and two lover are jumpered. Thank you all for help!
