Lap Simulation
Lap Simulation
I wasn't sure if this should go here or in other topics but I figure you folks must know something about simulation.
I am interested in utilizing a lap simulation software for my Formula SAE team. The main use this program would see is to justify decisions and give our team direction. For example, how does 10% increase in power affect our lap times and points? How does a 10% decrease in weight affect our times and points? Would the increased load from aero significantly decrease our times? etc. These sims could then be used to justify the addition of a turbo or going to a single cylinder engine vs 4 cylinder etc.
We don't need a F1 level simulation software, but we need something that can tweak the major variables of concern to us on a track we can define(essentially autox):
Power, and possibly powerband?
Weight
Tire mu, possibly dynamic
Cd
Frontal Area
and it wouldn't hurt to be able to change track width, cg, wheel base, know fuel consumption and some other parameters.
What I've come to seek advice on is if anyone has any experience with Bosch Lapsim(there is a noticeable lack of information) or similar software(such as chassissim). I have been toying with the idea of writing a simulation myself in matlab. A few teams have done this but I would have to learn a lot in matlab and I think it would take a bit. I figure why reinvent the wheel if someone has already done the work for me.
Essentially, to anyone who has worked with these programs are they capable of doing what I seem to be asking?
Weight
Cd
Frontal Area
RE: Lap Simulation
If you FSAEers still get access to ADAMS then there is a laptime optimiser in that, I've never used it in anger.
If you watch how Lapsim works you'll realise that writing your own is not impossible, especially if you ignore the bells and whistles like Pacejka style tire models and just use friction circles. Whether that is a good use of your time is a separate question.
Cheers
Greg Locock
RE: Lap Simulation
That sounds great then. It is nice that a program can do what we want for free. I could probably write my own but I am not the best person on the team to do it and it would be nice to have simulations by the start of the school year so major decisions can get the green light ASAP.
One other question(There really isn't that much info on google about lapsim, go figure), I read somewhere hinting that lapsim needs to run a full start to finish lap in order to function. As in point a to b rallys and a drag race wont work, is this correct?
RE: Lap Simulation
Yes, the main module only runs full laps. It works forwards and backwards from each apex. It also has a straight line performance predictor.
Cheers
Greg Locock
RE: Lap Simulation
One question. I'm having trouble installing it with windows 7. I go to run the msdinstall and after a bit it comes up and tells me "install not complete" and then I have no option but to exit. I tried restarting, redownloading etc but have had no luck. Thoughts?
RE: Lap Simulation
I've attached a picture of the main page so you can see what its like.
