2 general questions about modelisation on abaqus
Hello all,
I have two small questions about Abaqus, I hope you can enlighten me.
It's been a while since I work on Abaqus and there are two things that I never understood / used:
1) when I do meshes I always meshes independent, what does it change for the calculation if i use dependant?
2) what is predefinifield? it is used for what? you have an example please?
Thank you in advance
A +
A +
RE: 2 general questions about modelisation on abaqus
A predefined field would be typically used when you are importing temperatures for thermal loading. There are other cases too, which are explained in the manuals.
Tara
http://tinyurl.com/4ydjg7m
