Roark's - possible error in tabulated values
I am looking at Table 11.4 "Fomulas for flat plates with straight boundries and constant thickness", case 7a, tabulated values for Beta 2, of Roark's Formulas for Stress and Strain, 7 edition, 2002:
The values seem to be parabolic and not linear, whereas, the values for similar tables appear to be linear. So:
Q1: Does anyone else see this, Perhaps in a differnt edition?
Q2: or have I been looking at this book for too long and I'm "stressed".
Any suggestions would be appreciated. Thanks.
There are days when I wake up feeling like the dumbest man on the planet, then there are days when I confirm it.
RE: Roark's - possible error in tabulated values
I've looked into this stuff before and thought it was ok ... and Moody's report includes a lot more data.
TTFN
Chinese prisoner wins Nobel Peace Prize
Steven Fahey, CET
Brian
www.espcomposites.com
Table 11.4:Formulas for flat plates with straight boundries and constant thickness
Case 7a:Rectangular plate, one edge fixed, opposite edge free, remaining edges simply supported. Uniform load over entire plate.
Table for Beta values (Beta2): my book reads (from left to right).048 .190 .386 .565 .730 .688 .434
This is for stresses at the free edge in relationship to the a/b ratio.
In the sixth edition, it is table 26. The beta2 values are the same in the sixth as well.
The results do seem a little odd, I agree. Perhaps you can run a quick FEM to check it out?
Brian
Thanks. I was wondering what was in another edition. I downloaded the Moody document. Now I have to decide which is faster: a FEM analysis or a numerical review of the data in Moody? (since they are not identical)
using Raork/Moody will always be a compromise, as you'll have to conservatively model your loading to suit their cases (I expect).
FEA Should/Might be pretty quick, and should reasonably confrm Moody (who worked with a pretty coarse grid displacement model).
ESP, sorry I missed the point, which clearly the OP got.
For those of us who do happen to have a copy of Rourke handy (mine got lost) may I suggest you post the problem with the boundaries so that we can check it against Timoshenko or some other well known reference.
go to www.hpb.com , they have several copies starting at $6.00 to $80. (US). That's where I got mine.
ht
With this FEM solution, you can input arbitrary boundary conditions and plate aspect ratio.
I compared it to Roark's solution for all 4 edges SS and it was within 10%. The interesting part is that Roark's does not have the (1-v^2) term you would expect for a plate. Perhaps it is buried in the coefficients, but that would assume a value for Poisson's ratio.
In any case, you can use this to compare the solutions to Roark's to see if the trend is correct. I haven't checked it out yet. Just download the associated CalculiX open source solver that I have linked in the Excel file.
Brian
Brian
Thanks for the tip
Brian
By using that value and this application in the first site below (under Plates -> Simple bending -> Rectangular -> 1 clamped,2 supp., 1 free -> Unif.load), I found values quite close to Roark's ones (within 1% for a/b=1, but with a 3% difference for a/b=3).
So Roark's values are again confirmed, within the limits of the coarse approximation used in the calculation.
However the dependence on ν of these particular boundary case is relatively large.
For ν=0 (with which primary stresses are calculated) the stress at the free edge goes down by 7% and for ν=0.3 it goes up by 3%.
It is also hard to understand how Roark manipulated Moody's tables, a closer reading of the paper would be required for that.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
