Note dialogue box memory
Is it possible to set the Note dialogue box so that the "origin" section is collapsed by default? When the note box opens it is too long for my screen and all I see is the "origin" and "leader" sections but I have to scroll down to see the text entry section. I want to collapse the placement section so that I can see the text entry box immediatley on opening the command.
RE: Note dialogue box memory
thanks in advance for any help
You should be able to first close the "groups" ( up-arrow) in the dialog that you want to remove, then click the , in the "dialog rail handle" , button "hide collapsed groups". ( a dash as picture) Then place a note on the drawing ( Some dialogs don't store the settings if the dialog is canceled.)
NX should as i said remember this setting.
I have seen that the Note dialog keeps opening up the "origin group" as soon as i place a note. - Irritating!
About the best that you can do is collapse the sub-groups inside the Origin group since they don't have an action items that need to be seen the next time you invoke the Note dialog. This will make that group as 'short' as it can be.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
