Double Wall Pipe- Pressure Vessel?
6" pipe, 2 feet long, built as a pyrolysis chamber for R&D, welded cooling jacket.
Gas side: T~ 600 C, P = 10-15 inWg vacuum,
Jacket: water, 40 psig, 20C in, 35 C out
R&D is over, we ran the system for a year, pyrolyzing salts and collecting the powders, all worked good... time to build a demo plant. The "chamber" is followed by 2" tube-in-tube, custom built conveying pipe, water cooled.
Is the chamber considered a pressure vessel, i.e. do I have to have it stamped? The same question is for the conveying pipe which also sees about 30 psig water pressure.
Thanks.
RE: Double Wall Pipe- Pressure Vessel?
One of the first things to consider is the size of the vessel. Below a specific volume and or dimensions the "vessel" is treated like a pipe.
Fzob, the "vessel" is made of a 6" pipe, jacket welded onto it.
Sounds more pipe-ular than vessel-ular to me.
Good luck,
Latexman
The ASME BPVC code section VIII U-1 scope will provide the answer to your question.
For such a high temperature application an option is to build to the code but not have it stamped. (assuming it does not need to be stamped)
Operating pressure or design pressure doesn't matter.  RELIEF pressure does.  So:  what is the maximum pressure you're setting the relief devices to?
On the water side, one could argue that it's water in a jacket- not generally a code item, if properly relieved.  The tubeside is running under vacuum, but unless it is relieved below 15 psig it will either be a vessel or B31.3 pipe.  If it is indeed relieved below 15 psig, I'd argue that it's nothing- neither B31.3 pipe nor a vessel- but since B31.3 even regulates piping running below 15 psig if the temperature is high enough, others would argue that this thing is a B31.3 pipe regardless.
I'd design and build it to a code regardless.  Whether or not you obtain the stamp is a matter between you (as owner) and your regulator- or your insurance company.
40 psig is the backpressure in the cooling jacket.
