IMPORT DXF
IMPORT DXF
Hello
Probably it has been asked several times, but I have problems importing dxf and dwg files. Most of the times only a few lines are imported. Does anyone know how to improve this? I work in I-deas 12
Thanks in advance and best regards
Nibola
Nibola
RE: IMPORT DXF
Check your view scale after you import the file also.
RE: IMPORT DXF
RE: IMPORT DXF
Thanks to both of you. The problem is that the drawings are sent by a costumer and I don't have Autocad at work, so I cannot explode blocks or import in a different format
RE: IMPORT DXF
Try increasing the paper size on the drawing sheet to a much large size 10000 x 10000 or similar. Now move all of the views into the middle of the sheet and change border size of all views to the size of the sheet. Extra geometry may appear.
RE: IMPORT DXF
Thank you IdeasNative. I already tryed it before, but doesn't work. Just some lines and text are imported. I think that we should migrate to a newer version of I-deas, or to import from older versions of Autocad.
