Need a simple Irregular Cross Section River Hydraulics Calculator
I am not needing a full model, I just need to check some spot cross sections for a drainage study and I, at one time, found a really cool simple calculator program that was very well done, graphics were cool and it allowed river style sections, ie with multiple offset and elevation sets to define a cross section.
Unfortunately I lost the link and can not find it again after much looking.  To my shock there seem to be almost no simple irregular cross section calculators out there.
Any help is appreciated.  I am trying to not get fed up and write my own, as that seems silly.
Thanks....
RE: Need a simple Irregular Cross Section River Hydraulics Calculator
If you're just looking for normal Manning's flow, you can do that with HydroCAD, including the free Sampler.  Although HydroCAD is commonly used for a complete runoff and routing study, you can create a project file with a single reach in just a few minutes.
Inside the reach select "Custom cross section" and enter the elevation/offset values to define your channel.  You can use a separate Manning's value for each segment, or a single value for the entire section.
When you're done you can get complete stage-discharge and stage-storage data for the channel.
Screen shot here - middle of the page:
http://www.hydrocad.net/info8.htm
Peter Smart
HydroCAD Software
www.hydrocad.net
In HECRAS you can use the hydraulic calculator to evaluate an individual xsec.  One can write a spreadsheet to do the same thing.  FHWA's Hydraulic toolbox has a cross section routine in it that will compute normal depth, velocity and etc...
http://www.fhwa.dot.gov/engineering/hydraulics/software/toolbox21.cfm
Thanks guys, I have downloaded these and greatly apppreciate the informative and super quick responses...
Peter I have tried twice to activate the free version and I am not getting a code sent back...am I doing something wrong?  The demo button is not activating either.
Please register again and double-check your email address.  If you don't receive the activation details within 24-hours please send an email to support.  (see web for contact details).
Peter Smart
HydroCAD Software
www.hydrocad.net
