Small room rule in NFPA 13, 1994 Edition?
Does anyone have a 1994 edition of NFPA 13 handy (or does anyone know by memory) to check whether the small room rule was in effect at that time?
RE: Small room rule in NFPA 13, 1994 Edition?
Not 100% sure but I think it was.
I recall being able to utilize the small room rule when I started in 89.  I don't have a copy of the standard to back it up.  However, I am sure there are some on here that have copies that far back and will be able t provide you a definite answer.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
YES it is in the 1994 and must have been in 1991, because there is no change bar.
does it matter since it is allowed now???
Dealing with a city that is still on the '94 edition.  Thanks for checking!
My goodness - I could understand delaying adopting the latest revision until they had a chance to review it, but they are like 14 years behind on the updates.
Do you need a time machine to get to this place?
