wind load calculation...
hi..
i am designing a external pressure vessel for desalination process.i want to calculate wind load acting on the vessel and load acting on the support.the details are given below..
1. from bottom cone height:1.2m
2. above the cone, cylindrical portion height:3m
3. the vessel is to be situated at 11.5m cd
4. the basic wind velocity :39 m/sec
5. inside of the vessel full vacuum
6. the type of support is lug support
7. weght of empty vessel: 8000 kgs
8. operational weight:8000+15000 kgs
please kindly help me in this...if any more details are required i will provide...
RE: wind load calculation...
you.
I gone through the Moss book...but i feel the information is not clear..
Can You suggest some other authors book..
You can try by the the following authors.
Henry H.Bednar
Megyse
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
