Connector Help
Connector Help
Hi, I'm looking for a connector that can be mounted on a sheet metal panel and connect two wires.
Essentially this:
htt p://www.ra dioshack.c om/product /index.jsp ?productId =2102840#t absetBasic
but it needs to be rated for about 40A.
Please let me know if I can provide more information.
Chris
Essentially this:
htt
Chris
RE: Connector Help
You should mention the voltage you will be connecting.
If you use two connectors there may be a back feed when one is connected and the other is not. In some installations this is not acceptable.
Check (Google) welding cable connectors and battery cable connectors.
Here is a sample:
http:/
Bill
"Why not the best?"
Jimmy Carter
RE: Connector Help
Gunnar Englund
www.gke.org
RE: Connector Help
I think it is around 20V.
RE: Connector Help
RE: Connector Help
www.connectpositronic.com
RE: Connector Help
RE: Connector Help
The only 1 pole connector like that I can think of are what are being used in Solar Panel installations now. Some of those are rated at 40A, like the Wieland PST series. You want the "Bulkhead" connector for your panel, then you will have to use their mating plug. You can get the bulkhead connector as the male or female, but be careful with those Wieland part numbers, they seem to have some gender confusion as I recall.
Other people make these solar connectors, but most are rated 30A, I think Wieland may be the only one that is 40A.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
RE: Connector Help
You also might check into welding connectors (google it). They look something like banana jacks/plugs, but are larger, and sold by many welding supply companies.
RE: Connector Help
Will this connector be switching 40 amps (plugging in to a live circuit) or just conducting the current once it's mated?
How many insertion cycles do you need?
RE: Connector Help
RE: Connector Help
