Exploded Assembly duration
Does anyone know if it is possible to extend the time over which an assembly explodes and if so how? At the moment I seem to be limited to 8 seconds no matter how many steps there are.
RE: Exploded Assembly duration
You can probably save the animation as a .avi file and use post-processing software to extend the time.  Otherwise you can look at 3DVIA Composer if you've got some cash to spend.
Dan
www.eltronresearch.com
Dan's Blog
Use the animation wizard to do it. You can easily control the length of the explosion.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Thanks, I'll give that a try.
