FRAME PAD EYE CALCULATION
Anybody can help me?I would like to know how to calculate properly pad eye calculation in my attached drg.Padeye distance and thickness and welding size.
RE: FRAME PAD EYE CALCULATION
Please explain your background and engineering experience a bit. Are you an engineer, a drafter or a tech person? You have to understand your own problems well enough to ask intelligent and meaningful questions. And, you have explain your problem well enough so other engineers understand basically what you are trying to do and what you are actually dealing with. You have to use terminology that other engineers understand. You would do well to look for a local mentor or look to one of your supervising engineers for help, where they can really see what you are trying to do, draw you some sketches as you talk about the problem, and point you at the proper reference materials and codes which you must design around. They can also look over your shoulder regularly and keep you on the right track. They can better guide your development than people on a forum like this can.
The measurements are in mm's?
As I see it, it's a vertical jib with a horizontal boom with three pulleys (with each a point load), but with a hinge at the bottom of the jib?
A drawing in 3D, or with colors for the different parts in the assembly, might already help...
