Need help machining 3.5mml hole low roughness
How to make a hole dia 3.5mm. max roughness Rz 6.3, steel 12L14 deep 7 mm
Need help machining 3.5mml hole low roughnessNeed help machining 3.5mml hole low roughness(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Need help machining 3.5mml hole low roughness
Your OP is lacking a lot essential information, like all tolerances, number of holes, blind or through holes, and edge radius
A little more information might get a more complete answer.
Here are two approaches to produce smooth holes with high precision.
Use a rigided setup with sharp drill bits recommended for your material and hole size. After the hole is drilled slightly undersized you can use a round broach and burnishing tool to size and improved the surface finish. Another approach would be to use Ballizing to achieve the required finish and size.
http://www.circlebroach.net/broachtypes.php
http://www.precisionballs.com/Ball_Sizing.htm
They also have Nylon/Abrasive tube brushes that maybe able to finish the part if you go the drilling route.
I've used Micro Group numerous times but there are others that cut to length.
http://www.microgroup.com/index.html
