Cracked gypsum underlayment
I am currently investigating a project where the gypsum underlayment has cracked. It was installed on the 3rd-floor of an existing 60 year old structure, over a cast-in-place concrete slab & joist system. The thickness is around 3/8" and has been topped with an epoxy coating. Some of the cracks are longitudinal, sometimes occurring on beam lines, or occur at door openings or intersections of hallways. The later, to me, would seem to be shrinkage issues.
Others are a "spider web" effect, radiating outward from a point.
The cracking is extensive and varied. Some have been repaired and have not recracked. The existing concrete slab in the repaired areas was not cracked, so it is not believed to be a telegraphing issue.
I have been scouring the internet to find a resource on gypsum underlayments, with little success. Does anyone have experience with a similar issue or a resource you'd suggest?
RE: Cracked gypsum underlayment
3/8" seems awful thin. Is it likely that this was just a leveling course?
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
But in any case, gypsum underlayment is not meant to be exposed or meant to be a structural entity...only a fill layer.
I would definitely expect it to crack at 3/8" thickness for minor deflections in the supporting structure below.
Since you have cast-in-place concrete below this and if you want to use an epoxy topping, I would use a cementitious leveling course such as Laticrete or SikaTop 123.
