Need INFO. on ANSI B16.5
Can stainless steel 304L/316L produce by machinig from hot rolled stainless bar stock? flanges type SLIP-ON, WELD-NECK, BLIND. Does the standard required only forging process?
RE: Need INFO. on ANSI B16.5
The ring formed from plate shall have original plate surfaces (lamination direction) perpendicular to the axis of the finished flange.
The joint between ring and hub shall be butt welded and controlled according to the code.
