Choker Design
Choker Design
Choker Design
Dear Colleagues:
I have checked for a Cinch to lift a equipment using 2 of this type. We have checked critical points and we know very well the responsibility of kind of lifting. Problem to me at this point, I try to evaluate using Moss pag 416 (transp and erection ....)but unfortunatelly we will apply another rope angle (57 instead 30 as worked example).
Looking in Roark, Moss indicates a combination valid for 5Th edition (table 17 cases 12 and 18 combined), so I have 6th edition and proposed combination is not applicable. Could you explain me which cases are applicables in 6th edition?
Thanks in advanced
Luike
RE: Choker Design
Luike (Mechanical)
Reference DR. L.C. Peng  "PIPE STRESS ENGINEERING"
choking force, ring girder supports, 180-82
choking model
discontinuitys tresses|, 4243
See also Kellogg's choking model
choking phenomenon in gas flow, 392
RE: Choker Design
Dear Colleagues:
Thanks for your promptly answer. I'll check in these books, LSThill, thank's again.
