Difference between Maintenance Release and Maintenance Pack?
Hola!
What's the difference between a Maintenance Pack and a Maintenance Release?
I ask because June 17 saw the release of Maintenance Release NX 7.5.4 (1.15 Gb) which I DL'd and installed.
Then on June 24 Maintenance Pack 2 (MP2) for NX7.5.3 (205 Mb) was released.
Should I install Maintenance Pack 2 despite the NX version now being higher (7.5.4 vs 7.5.3)?
RE: Difference between Maintenance Release and Maintenance Pack?
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Full release (7.0.0.0)
Point release (7.2.0.0)
Mainteneance release (7.2.1.0)
Maintenance pack (7.2.1.2 - 7.2.1 mp2)
Full Releases - anything new is allowed
Point release - limited new functionality, usually to prepare things for the next full release
ususally upward and downward compatable within the full release number
Mainteneance release - bug fixes that must get out, ususally recommended that all customers upgrade to this
Mainteneance pack - specific to a MR, usually only installed at the direction of GTAC to fix a specific bug
The later MR version (7.2.3) will have the fixes from 7.2.1 and 7.2.2 included.
Ben Loosli
A Maintenance Pack (MP) is a patch that contains fixes. Customers usually only install these if they need the fix for a problem they have reported.
FYI Ben - a point release is not backward compatible ;*)
Mark Rief
Product Manager
Siemens PLM
Any idea why I am getting this error:
Install Failed "Failed to open registry key SOFTWARE\Unigraphics Solutions\NX\7.5.0
Possible causes for the problem:
The 32 bit version of NX is not installed.
The file "C\Data\dvdrom0754\ugs_update0754\run_ugsupdate.ini" does not properly define nx_registry_hive."
I currently have NX 7.5.3.3 loaded.
If the MP explicitly says that it was built for NX 7.5.3 than DO NOT attempt to install it on NX 7.5.4.
vball85jb:
Sounds like you were trying to install a 32-bit update on a 64-bit version of NX.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
