Vibration control of looms
We need to reduce vibrations transferred from rapier loom to the building structure and also have to ensure that the machine vibrations do not increase. Kindly suggest any solution/s. Thanks in advance.
RE: Vibration control of looms
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
Have you done some vibration analysis to understand the frequency(s) of the vibration of interest on the building structure? Alos the amplitude, to understand how much reduction would be 'enough"?
Is the vibration at a frequency related to rpm of some component?
Where does the limit on "machine vibration" come from?
Dan T
Mike Halloran
Pembroke Pines, FL, USA
Fe
