Symmetric model generation / results transfer
Hi Everyone,
I am trying to use the options Symmetric model generation and Symmetric results transfer. I have read the documentation but still cannot succeed.
The model is made with 3 differents parts (2 analytical rigid and 1 deformable)
I have joined an example of the axisymmetric inp file.
I would like to revolve the results of this axisymmetric model in order to continue with a full 3D model.
The error I have is:
***ERROR: Node 2 does not belong to instance 'LOWER_DIE-1' and cannot be assigned to instance node set 'ASSEMBLY_SAMPLE-1__PICKEDSET2'
I don't understand why...
In my 3D inp file I have written:
*HEADING
*RESTART,WRITE,FREQ=1
*SYMMETRIC MODEL GENERATION,REVOLVE, NODE OFFSET=3600, ELEMENT OFFSET=7000
0.0, 0.0, 0.0, 0.0, 1.0, 0.0
0.0, 0.0, 1.0
360.0, 36
*SYMMETRIC RESULTS TRANSFER, STEP=1
Is anyone can help me with this problem please?
Thanks in advance,
Best Regards,
Pipo
*HEADING
0.0, 0.0, 1.0
360.0, 36
Thanks in advance,
Best Regards,
Pipo
RE: Symmetric model generation / results transfer
I guess you cannot use it when you have an assembly of instances.
Thank you for your help. I have found the option to change the format of the inp file.
Best regards,
Pipo
