Liquid Seal Vacuum Formation in Tank Gravity Draining Liquid Outlet
I'm installing a drain tank which will normally drain diesel fuel. The tank can occasionally also receive hydrocarbon gas. This is vented to a safe area via the tanks vent, but hydrocarbon gas must not be allowed to follow the liquid outlet line i.e. gas blow-by must not occur. To prevent gas blow-by, the liquid outlet line (which simply gravity drains to another tank) has a simple 'U' tube configuration to act as a liquid seal.
How can I determine if my liquid seal (U tube arrangement) requires a vacuum breaker?
My concern is that the liquid outlet could form a vacuum in the gravity draining section (downstream of 'U' tube arrangement) and siphon tank liquid content, thereby allowing gas blow-by. If I concluded that vacuum formation was possible, I would simply install a vent line downstream of the U tube arrangement.
Thanks in advance.
Thanks in advance.
RE: Liquid Seal Vacuum Formation in Tank Gravity Draining Liquid Outlet
There was a detailed discussion of the problem in thread378-289211: Hydraulic Design 101 - Air at Highpoint
Katmar Software - Engineering & Risk Analysis Software
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
h
