Methods for small parts for Medical Instruments
I'm starting work in a new field as a draftsman. Looking for an overview of how small parts and parts 2mm in size used in a mechanisms (3 to 5mm in size) are manufactured - if Titanium, are most parts EDM machined and what are the limits of detail size? If plastic is everything moulded at this size or can conventional machining (obviously at a small scale) be done by a specialized vendor.
Method of joining simular materials - if metal - laser welding? and at what scale (size limits)
What are the wall thickness limits on turnings etc
What level of tolerances can be achieved
Pivots in a moving mechanism that I was looking at seem to typically be rivets.
Can press fits be achieved at this scale?
Any comments or links would be helpful..
Thanks for reading
Thanks for reading
RE: Methods for small parts for Medical Instruments
Bruce
www.accuratus.com
Mike Halloran
Pembroke Pines, FL, USA
Metal parts of this size can be easily metal injection moulded if your quantities can justify the tooling cost.
