K Series Joist Designation
A roof framing plan specificies 16K 202/112 Joists. The designation I am accustomed to seeing is for example 16K2 joists. I imagine the numbers 202/112 refer to the allowable loads, but why two numbers? What does each really mean? What correlation is there between both types of designations?
Thanks for your time.
RE: K Series Joist Designation
First number is the total allowable, the second is live load only.
And the second number is for live load deflection - based on L/360.
Vulcraft will for free send you some VERY good manuals explaining all that.  And they probably have it on-line.
Also - go to SJI.org - good info there.
