allowable compressiblw stress
hello.
in bednar page no 157 in rankines formula the "r" has to be calculated. in page no 156 the "r" value is given as 0.289*0.625 under the fig no.5.9.
any body can you please tell me what are those values(0.289 and 0.625)...normally we will use r=sqrt(I/A)
RE: allowable compressiblw stress
The 0.625 is the thickness of the gusset shown in Fig. 5-9.
now i got another doubt from your answer...before calculating the gusset thickness we need to calculate allowable compressive stress to arrive the thickness..may i know how come it possible to calculate gusset thickness without allowable compressive stress
Now i got one way to solve the problem...i got some value for gusset thickness by assuming a value in rankines formulae..after that i checked back the gusset thickness with the rankines formulae..this value should not exceed the allowable stress for material given in ASME code for materails section-II..please can you confirm me whether am i going right r wrong...
