electric motor mounting vs drain/purge plug
The motor below shows the grease fitting located at ~ 3 o'clock and the purge plug at ~ 9 o'clock.
The installation is outdoors.
Should we re-orient the end bell to locate the purge plug at the low point of the housing, 6 o'clock?
RE: electric motor mounting vs drain/purge plug
Muthu
www.edison.co.in
Bill
"Why not the best?"
Jimmy Carter
