How can I create a link between a note and a dimnesion in NX 7.5?
Can anyone answer me how can I create a link between a note and a dimension in NX 7.5?
The note is a kind of appended text, a multiline one, it is positioned under the dimension line and I want it to move in accordance with the dimension line.
I already tried to make it an appended text during dimensioning, but in this case the text is positioned above the dimension line, not under this, as I want.
This is frustrating, because in the right click menu of the note there is only the option to associate the note to a view, not to a dimension.
Thank you!
Thank you!
RE: How can I create a link between a note and a dimnesion in NX 7.5?
If that doesn't work for you, you can associate a note to a dimension with the origin tool. Try out the XY offset option and be sure to tick the 'associative' option.
Indeed, using the options of appended text command, I didn't obtain the desired result. Instead, I got what I wanted using origin tool.
Thank you again.
