Steam Cooling for Discharge
Hi All,
I have excess steam that I need to dispose of - about 10KW (30 lbs/hr) of steam at 15 PSIG. Unfortunately, I can't blow it off to atmosphere. I need to condense it and cool it down to 100F before I can discharge it. I'm steering away from coil condensers because I don't have access to a chilled water loop or treated water and I'm afraid using raw water will lead to mineral build up over time thereby causing failure. Ideally, I am looking for an off the shelf product that condenses steam by injecting it into a bath of water. The device would use raw water to condense the steam and regulate condensate temperature. Does anyone know if a device like this exists? What should I search for. I'm sorry if this is a basic question but this is not my area of expertise. Please let me know if this is not clear. I appreciate the help!
Best,
Steris
Best,
Steris
RE: Steam Cooling for Discharge
rmw
Thanks for the tip. Searching for barometric condensers didn't turn up what I was looking for however I did stumble upon sparge pipe tank water heaters. This seems to be similar to what I need. Anyone know of any of these that come with water temperature control? Since I can't adjust my steam discharge rate, the raw water would need to be added at a varying rate to maintain condensate discharge temperature.
Best,
Steris
http://
So eventually I found what I needed. It's called a bubble type direct contact condenser. Watson McDaniels makes one using a flash tank and a thermostatic wax type temperature actuated valve to control cooling/makeup water. Thanks all for the help!
Best,
Steris
http://www.komax.com/
