Converting a Solid Works "Assembly" into a "Solid Model"
Hey,
Im new to the site so excuse me if I am not following the correct protocol. I just finished my assembly drawing of a full casting, runner, sprue etc. Unfortunately I neglected to realize that in order to run the simulation software I need it to be one solid model. Is there an easy way to alter the assembly without redoing everything??
Wade
RE: Converting a Solid Works "Assembly" into a "Solid Model"
If the simulation software does not recognize multi-bodies, you may have to use the Combine tool to merge bodies.
Dan
www.eltronresearch.com
Dan's Blog
Certified SolidWorks Professional
The only two that look close are:
"Computational Optimization of Small Molecular Structures"
"Computer Oriented System for Manufacturing Order Synthesis"
Or, it may not be an acronym? You may need to write to SolidWorks and ask them.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
-Dustin
Professional Engineer
Pretty good with SolidWorks
I have another question. I am using the simulation software Quikcast. After I save the "model" as a .sldprt I need to convert it to a .stl to run on the simulation software. When I try to convert the model to the .stl it states that my part geometry is not correct to convert. The actual geometry is irrelevant because I tried a variety of models. How can I get around this?
Wade
