A270 Sanitary Tube vs A312 Pipe with Sanitary Fittings
If you are designing a piping system using sanitary fittings (Tri-Clover clamps for example) is it best to specify A270 sanitary tube or A312 SMLS SS Sch 5 or 10 pipe with mechanically polished finishes? I only need 32 Ra microinch finish at moderate P & T food service.
My concern is that the sanitary ferrules seem more common for A270 tubes instead of IPS pipe. WCB-Flow has pipe-to-tube adapters but seems to go against industry standard.
gpbche
gpbche
RE: A270 Sanitary Tube vs A312 Pipe with Sanitary Fittings
donf
